- 06 LS MS6
07 BM GT (shell has been struck from the roll)
I actually bought my LED bulbs to replace my stock filament bulbs from v-leds, for my tail turn signals, side markers, reverse lights, parking/signal light, and interior lights. But I would not use these strips for this application, they are not even close to as bright as the LEDs I found. I first tried using the strips v-leds supplies and it didn't turn out like I wanted, too dim and the LEDs spaced too far apart. For bulb replacements I would highly recommend v-leds.com, and for those who don't know, make sure you get the resistors if you replace your turn signals or they will flash super quick as if your turn signals are burnt out. But for LED strips oznium makes the best i've seen so far. Not dissing on your post at all, just thought I would let you know their strips aren't the best for exterior application, interior they work great though.
Good to know, OZ has those same strips for more $ than the VLED equivalent, But OZ seems to have a much greater selection in the strip type of application.
They do pack those leds in on that strip, looks like twice as many as the ones with a black background, I found this on the oz site as well :
http://www.oznium.com/side-emitting-led-strip
not as many size options , but mebbe a nicer install when not illuminated.
+1 on the resistors, unfortunate, but the flasher on our car is embedded in the pcm and not a candidate for an electronic flasher
I wunder if I can get a strip of these into the headlight shell someway??
