Stock wheels from a __________ fit on a Mazdaspeed3 without modification
AutoEuphoria
'08 CPW Mazdaspeed 3
Can we get a list? Think it might be kind of cool/helpful (trying to keep an alphabetical running list - thank you for all the contributors)
- Hyundai Tiburon (2001-2009 - 16" ones are great for snow setups)
- Mazda Mazdaspeed6
- Mazda Rx8
- Mazda Rx7 (FD)
- Mazda Mazda6
- Mazda Mazdaspeed Protege
- Mazda MX5 (2005+)
- Mazda CX7
- Mazda CX9
- Mazda3 16"+
- Mitsubishi EVO VIII
- Mistubishi EVO IX
- Mitsubishi EVO X
- Mitsubishi 3000 GT VR4
- Mitsubishi Eclipse (4th gen)
-Mazda6
-Mazdaspeed Protege
-Mazda MX5 (2005+)
-Mazda CX7
-Mazda CX9
-Mazda3 16"+
-Mitsubishi EVO VIII
-Mistubishi EVO IV
-Mitsubishi EVO X
-Mitsubishi 3000 GT VR4
-Mitsubishi Eclipse (4th gen)
- Mazdaspeed6
- FD Rx7 (I believe)
- Mazda MX5 (2005+)
- 2001-2009 Hyundai Tiburon (16" ones are great for snow setups)
- 2002-2008 Honda Accord (not sure about other generations)
- Mazdaspeed6
- Mazda MX5 (2005+)
Accords use a 64.1 hub bore, we have a 67.1mm bore. So they would have to be machined to fit. Subaru STI rims are the same way (2005+).
Of course Mazda RX-8 :)
And I thought at one point I saw an MS3 with Scion tC rims on it. They're 5 x 114.3 and the offset is 45mm. Not sure of bore size though.
Scion's use 5x100mm bolt pattern. There are a number of other rims that look a lot like the Scion rims though.
My bad - I did a quick Google search and a few places posted that the Scion tC rims were 5 x 114.3.
5x114.3 is pretty common for imports in general (Subaru doesn't for sure.) Also, Lexus uses some of that size too.
yea scions should use a 5x114.3...
and subarus are 5x100 if i remember right so sti rims shouldnt be able to fit
Scion xB is 5x114.3, TC is 5x100.
Why would they do that? (hand)
Also, a lot of american cars are 5x114.3mm, because it's 5x4.5inches!
93-96 Ford Probe: 5x114.3, 67.1mm bore
91+ Ford Crown Victoria is 5x114.3
etc...
http://www.discountedwheelwarehouse.com/Vehicle_Bolt_Pattern_Reference.cfm has a lot of pattern/bore dimensions, a good reference to double-check everything so idiots like me don't post wheels that don't fit!
the evo x wheels will fit but you must buy there lug nuts for them to work. iam not sure if that is the same for the other mitsubishi wheels.
The Scion XB does in deed have 5x114.3 but also has a 60.1mm hub bore. So doesn't follow the without modification part of the thread.
Anybody knows if 2009+ Mitsubishi Lancer Ralliart wheels will fit with no modification?
New Threads
