So, I have the Eiback Pro Kit springs installed and the SPC adjustable rear camber links.
So far, rear alignment is at Factory spec (can't find the numbers right now, but verified to the OEM manual and readings from the tech) and the camber links are doing their job. I believe neg camber is around 3.5 degrees and I'm looking to get into the 1 to .5 degree range if it works.
I'm looking for a more upright rear tire position and wonder if anyone has numbers they've come up with after some testing/experimenting. Setup is with 235/40/18 tires on 18x8.5 +50mm offset TSW Trackstar 5s.
On the fronts, the neg camber is what it is. Has anyone else found a front setup adjustment kit/link set?
