Westminster, it's a little northwest of Keene NH. About an hour and a half from Manch NH.
Oh GOD Keene, NH!!! I think i am banned from that campus!
hahaha
how the drivability of your car? I mean, thats a shitload of power to the front wheel...
dj you could always drop requested load below say 3k to make it a bit easier. I have my tune setup that way, at 3k its like flipping a light switch and im gone lol
thread cleaned up...try to stay on topic (drinks)
hmmm...your numbers seem a little unrealistic. I'm not hating or calling bs, but it took almost a fully bolted car and tune to make 291 honest, uncorrected whp on a dynojet @19.6psi. Well, I guess my car isn't tuned to shoot fireballs from 3k-4k...just kidding![]()
My tune is great, and I'll try to post the last pull as soon as I can get around to it. I have noticed that the boost delivery is wayyyyy different depending on when I get into the gas. Starting at 2k rpms, boost builds gradually from 16@3k and builds to 19.6ish by 4300 and tapers off gradually by redline. If I get into the gas at 3500, boost hits 23.8 and holds over 20 until until almost 5k. Needless to say the car makes a ton more power at this point but the dyno reflects a pull starting @2500. Anybody else notice this? I can't call it a spike because it holds, but will never build to that level starting below 3k rpms. All vitals look good at that boost level as well. Thoughts?
Those are nice #s. I did a dyno session this past weekend. I was happy I got to 300 hp with one of my pulls. The average was 270 hp. I was using ots stage 2 with cai/91. I now need a fuel pump. On one of the last pull the fuel pressure dropped to 800 psi. It was done also on a dynapack dyno. Afterwards, they changed my AEM cai for their sri. The pulls were almost the same. The only problem was the afr(really lean). I ended up reflashing with my original ots map. That is when it did 304 hp and 320 lb-ft
I have a question for those who have a custom tune. When the tuner does a map change or adjustment to the ecu, is there a learning for the maf?
what do you mean? he will recalibrate the maf if he knows what hes doing
Doesn't the ecu need time to make adjustment for its fuel trims?
i asked the same question...
the tuner should be calibrating the maf tables first. once done there is no learning period needed...
a really good tuner will have you calibrate the maf through email (log driving, make adjustments, log driving, rinse and repeat) before you ever get to the shop as to not waste dyno time!!
