I filed a report with the better buisness here is Mazda'
s Official First Response:
Company's Initial Response - Posted 12/09/2009
To Whom It May Concern: This letter is in response to your request regarding the claim made by K***** *****, complaint ID 98******. Upon review, it has been determined by our district service representative that Ms. ****** vehicle has many aftermarket modifications. These modifications include an aftermarket blow off valve, cold air intake, modified exhaust system (down pipe welded in) and a missing/modified catalytic converter. Due to these modifications Mazda has branded the powertrain warranty for this particular vehicle. As such the turbo will not be repaired under warranty. We appreciate you allowing Mazda an opportunity to clarify our point of view on the situation. If you have any further questions please contact me at 800-222-5500 ext. 1157. Regards, Paul Steinbruner Specialist, Customer Assistance Mazda North American Operations File: 127*******
Initial Response Summary
Aftermarket modifications on vehicle - no powertrain warranty.
Hilarious!! The Cold-Air intake is a Mazda-Speed (green light warrenty) product. I have a Full recirculation Valve (not a BOV) and the down-pipe is catted Cobb application that is bolt on not welded. Who welds on their on exhaust componets? Sounds like their district service representive is a retard!!! Of course I get to give a rebuttle and now it goes to littigation. Im willing to return the Car back to stock.
Has anyone had the Smoking Issue with the downpipe then returned it back to stock and it stopped?
Second Update: I have had the PT-Performace fix installed for about a month now. Although I have to admit it has significantly reduced the smoking under normal driving conditions. But it still smokes after a little bit of load and then iddle like at a traffic light after a freeway-drive. havn't had any luck with completely solving the problem. Any ideas why? Any one in the same situation?
Seriously, SEARCH. Even Google...the MS3 is FAMOUS for smoking turbo's when you have a DP. As for your warranty, return to stock and continue your litigation, gonna cost you more than fixing it yourself, but go for it. You have mods so you are SOL, however it is illegal for them to flag your entire warranty, they can only decline to fix the turbo or replace the turbo, which is smoking because your DP btw...but it's not caused by the DP, if that makes sense. The stock DP provides more pressure for the seal to counter the pressure from the oil-side, when you remove this pressure, or reduce it, the oil blows past the seals. The true problem is too much pressure on the oil-side, but your DP creates the symptom of smoking...crappy situation.
