Z
Z33-TEC
Ill have you know we have a flat torque like of 140 throught the the gears
Word, I remember I wanted a msp when they came out but could not afford one at the time. When the ms3 came out and I was baller at the time I had to pick one up. It was meant to be, after all the first car I learned how to drive in was my mom's 323 turbo.
Thanks alot mom, now I'm a boost addict.
My mom got me hooked on it too, learning on a boosted saab ftw. (cabpatch)
yup, like the only 2stroke powered car in the world![]()
My name is Rick and I'm a boost addict, I use it while driving. I need help. LOL
it's more like a 1/2 stroke. 2 stroke produces power every second stroke and we produce power twice each revolution. could be 1/3 stroke. or 1/6 stroke, depending on how you look at it. this is getting complicated.
yep, it is like the only 2 stroke powered car in the world. that seems a lot more simple.
ill tell you this, its easier to put back than a piston engine. All you have is your housing, your rotor, and you e-shaft. Throw some gaskets and and bolts and your done.
Hey man, what's the background on ur Screen name? I used to be in the Marine Corps with a guy with the last name Dyer.
I want a rotary just to take it apart to see if I can put it back together.(boom01)
This is taken from a "renesis rotary engine design and tech" manual
"In the rotary engine, the rotor creates three chambers within the housing and three separate events in the 4-stroke cycle are taking place at the same time. Think of the rotor as doing the work of three pistons at once"
