depending on how much you want and if you do sell i may take the 15" steelies off your hands if i dont find a set before then
when are we talkin? if I've got the new set by then they're yours. I paid 200 last year around now and the tires have a winter left on em..
I also have to see how much it would cost to ship four wheels from wisconsin to maryland
Remember that a lot of Mitsubishi wheels will fit our cars too... so there are more options for cheap wheels out there.
Ur not refering to the evo wheels are you? I heard those had a different hub so ull need to get them drilled out.
Ordered a few things. Aem dryflow filter, Type S rad cap, TWM shifter bushings. Cant wait to get them.
I dunno about that, I am pretty sure mitsu shares hub bores across the board with their cars as does mazda. I know my 16" rx7 turbo wheels didn't have a large enough hub bore to fit over the hub bore on my talon
Hub bore on Subies is smaller. Iirc, the bore on most Mitsu's is larger, but hubcentric rings are cheap.
so.. still need some more input on whether or not to remove the embossing on the FD wheels. I'm 50/50 on it, it polishes up fine... so idk what to do..
Leave them for the classic look but removed would look clean. I would op for clean just a little more work but you decided not to then change your mind thats even more work?
plenty of work to do before I have to decide... I may get an air-powered band sander to do it.... idk how else I would do it without causing distortion in the wheel surface.
Lot's of new touches done over the past week.
Enkie RPF1 SBC 17x8.5 30mm Wheels
Falken Azenis 205/40/17 Tires
New Oem Strut Mount Plates
Peddars Control Arm Bushings
Protege5 Headlamps with TSX Projector Retrofit + CCFL Rings
55 Watt 5000k DS2 HID with PIAA Ion Yellow Bulbs in the High Beam
TWM ShortShifter/Boot/Bushings/ M1 Abrhams Gunmetal Knob
Also got my Go Pro HD in the mail. Woot Woot.
(Pictures coming soon)
well today i sold my hks. i may be trading my exhaust for a full 3 inch. but i got a question: do full 3 inch exhausts normally not got over the rear "axle"? im lowered and im kinda worried about scrapping.
also anyone know a good place to get bi-level HIDs for cheap?
Wow! cant wait for pics. Hurry buddy!
only under exhaust I know of is the apexi R1.. and I don't think thats a full 3"... custom, obviously up to you, but under axel is cheaper and easier.
well im pretty sure thats the one. is it a pretty good exhaust? it is the catback.
and i just ordered some 6000k hids.
