Running a stock turbo I can't imagine how that would happen, unless the radiator / fan shroud in your NA sedan is a whole lot deeper than in the MSP... and iirc the turbo inlet sits nearer the passenger side fan, or about where the two fans meet.
Dub you will hate your life if you stick with the stock fan and fit your intake in there. I had to take the fan out, attach the intake, tighten it down, and then FORCE the fan back down. I had to cut a part of the top of the fan so that I could push it back down into place. It wouldn't go over the top radiator hose attachment. That was one of the shittiest parts of the install and it is a TIGHT fit.
werd, and your sig btw is ******* awesome lolYep... now that I've seen the pic, the NA fan setup is way different. The driver side shroud is huge! I can see where the inside / center edge would be into the coupler.
On another topic (clearly a thread jack) Dub, do you know if any of the 01-03 NA sedans came stock with rear disc brakes?
