kyle's protege5
- 2002 MP5-T
TONS of Protege stock parts FS 1.8 and 2.0
I have a lot of stock parts for sale. I also have tons of nick knack clips and hangers etc, so email with what you need!
I'm gonna throw some prices up, i also put shipping charges in blue. The USPS has those one rate boxes so i hope i don't get screwed with my guesses.
I end up getting a ton of emails, and nobody follows through. So if you want it just paypal me the money and make sure you put in what you want. paypal is ajmarqueling2@hotmail.com
I WILL ONLY SHIP TO THE US AND CANADA.
I shipped an entire engine harness with every damn connection labeled and an ECU, never to be seen again. And the post offices insurance is a joke, good luck trying to cash it in.
Please email me andrew@marqueling.com for quickest response
JDM Intake manifold $85 $15 2.0 or 1.8, COMPLETE, Just like ours but with out the tumblers.
Water Pump $20 $11 about 20,000 miles
Cam Gears $10 $10 about 20,000 miles
1 EGR Valve $25 each $5 about 40000 miles on it, will fit 2.0 and 1.8
Crank Position Sensor $10 $5 2.0 or 1.8
Crank Pulley $10 $5 off of a JDM 1.8
Oil Pressure Sensor$10 $5
Roof Antenna $10 $5
Hood Prop $5 $10
2 Passenger Side Engine Mounts $5 each $5 just the part that mounts to the engine, sand blasted and painted black
Power steering / AC Belt $10 $5 about 1000 miles on it, gates part #K050459
Brake Booster $15 $15 auto or manual, abs or not, will fit all
Brake Pedal Assy $15 $15 off of an auto with all switches
Midpipe with Resonator $20 $20about 5000 miles on it
Passenger Side Mid Drive Shaft $10 $15 about 20000 miles
Upper Alternator Bracket $0 $5 have 2 of them sandblasted and clear coated
Power Steering Pump Tensioner $0 $5
2 Thermostat Necks $5 each $15 Sandblasted and clear coated
Automatic Flywheel $10
Knock Sensor $10 $5
JDM 1.8 EGR tube $5 Will fit 1.8 and 2.0$10
Dip stick Tube $5 $5 just the tube
Thermostat Housing $25 $15 With all tubes and hoses,water neck that mounts to head, including Temp sensor, and thermostat
Roof Antenna $10 $5
Hood Prop $5 $10
Knock Sensor $10 $5
