The old Slotege Partout
Status
Not open for further replies.
Joost27
More Power Made Me Slower
Contributor
2000 Mazda Protege ES V6
Ok here are the parts I have lying around.
All Prices are before shipping, and some are local pickup only, due to size. Also, paypal only, and I also have a lot of other parts that i have not listed, so if you need something let me know. The car is being taken away this friday.
99-00 Upper Grille - $30
99-00 Steering wheel and airbag, no flaws - $100 obo
3 x Door switches - $15 for all
1.6l Coils one has less then 3k miles and the other is original, wires have less than 3k as well - $50 for everything
99-early 01 "Protege" Trunk badge - $10
99-00 Gray Passenger window switch - $20
99-00 Passenger Headlight - $30
Gas Door - Red - $20
1.6L Cam Position Sensor - $25
Non-foulers need to be drilled for CEL tricker - $10
99-00 Amber Corner lights - $30
1.6l throttle body with gasket - $35
Fuse box cover - $20
Stock battery tie-down - $15
Wiper arms, mint condition - $25
99-00 stock swaybar - $20
Rear Deck tray with working 3rd brake light - grey - $25 Local Pickup only
1.8l stock airbox and snorkel - $40
Dimmer switch - $20
KLZE J-Spec Distributor - $55
Factory child seat anchors for rear deck - $20
Headlight rubber grommets - $15 - Sold!
99-03 Front Motor Mount - $20 - Sold!
Clock spring - $30 - Sold!
99-00 Driver Side Headlight - $30 - Sold!
Trunk Trim - Classic Red - $25 - Sold!
Stock Taillights - $50 - Sold!
Mint condition Taillights - $50 - Sold!
License plate lights, very clean - $10 - Sold!
99-00 Shift boot holder - $10 - Gone
Cruise Control bracket - $10 - Gone
Alternator less than 6k miles - $40 - Gone
Power Steering Pump - $40 - Gone
A/C Compressor - $50 - Gone
Upstream O2 Sensor - $20 - Gone
Downstream O2 Sensor - 10k miles - $30 - Gone
EGR Valve - $30 - Gone
1.6l Radiator with hoses - $30 Pickup only - Gone
1.6l Fuel Injectors - $35 - Gone
1.6l Fuel Rail - $15 - Gone
Shifter stabilizer bar - $30 - Sold
Wiper and light control switches - $30 - Sold
Stock coolant bracket, rusty but can be sanded and painted - $5 - Sold
Pics:
RIP Slotege
i thought thats what you ment:
my bad. do the 00's not have any??
the door switches i was referring to are the ones that tell the dome light to come on and stuff like that. Is that what you are looking for?
I also have the black lock switch thats mounted on the driver side door
Air temp sensor? Im guessing that they are the same (will do a bit more research in the meantime)
Also, did the 2000 lx's have the triangular sail panels in the front doors?
Cheers.
bingo..... how much?
idk like $10shipped sound good? not sure what they go for.
no its a dimmer switch to control the cluster, and climate control/stereo lights. then the other is a blank panel with a little light that was wired to an alarm system.
will the o2 sensors work on the 2.0l? if so ill take em..
O2 Sensors have different part number from autozone and advance, so they are different, no idea if they would still work though.
Cheers.
The 1.6 Air Temp sensor is built into our small MAF, the 1.8l and 2.0 have the same type of air temp. sensor that is separate from the MAF
yeah i searched for a while and got the same results of different part numbers. dont want to try my luck so ill pass.
thanks for looking into it though
hmm.. do you have the shifter assembly w/ the stab bar?? like.. it's a full 3 piece thing basically... i guess you're still keeping your control arms?
What happened to your car, why is it going away?
The one pictured in my sig is the one that got tboned August 1st. I now have a 00 ES in Classic Red that everything is going onto. These parts are just what I have laying around.
Boostedprotegelx:
The control arms went onto the new car last night. As for the shifter assembly I will have a complete setup once I swap the B&M into the new car. I can't get it loose from the shift linkage, so I have to swap that part with the new car, but after I will have a complete stock shifter assembly. If you want I can let you know when this happens. Might be tonight. Doing the tranny mount inserts tonight along with the rear motor mount. So, if I am feeling ambitious I will do the shifter too. Dragstrip day tomorrow! haha need to beat 17.95s 1/4mile that the old 1.6 put down.
bump mostly everythign still available. Want to get rid of it asap. Make offers
Status
