speedblue88
- 2003 Laser Blue P5
Another issue I have discovered today during an oil change. I use the Mobil1 extended performance, so I don't usually change it too often, as it's good for 15K miles or whatever. I think the last time I changed it was almost a year ago. I have driven about 12K miles since the last change. Anyhow, I drain the oil, and notice that the amount that came out of my engine is not the usual amount. In fact I measured it and only about 1.5 qts came out. Of course I usually put in about 3.75 qts, so this is rather alarming. What has happened to the oil? I have no noticeable leaks, and I never see any smoke or anything from the engine bay. The car runs fine, and gives no indication that there is any problem. No backfires, no nothing. I did notice a bit of a gap on the engine head, by the gasket, which I'm thinking might have something to do with it, but I don't really see any significant amounts of oil on the engine or anything. What could be causing this? Pics of the engine are below:
