Mazdaspeed2oo35 Engine Build Round 2
Status
Not open for further replies.
i don't think spain's water could be any worse than american
why don't you drink that rusty spainish s*** that was in his radiator then?
he used some supposed fancy antifreeze that ****** up his entire cooling system... his expensive mazdaspeed thermostat, down the drain after 3000 miles!
so now he's running the mazda coolant and that should stop this from happening again
Well ask the damn instructions you sent me, it says it there..
I just told you do not hook up anything except the knock sensor, ignition wires, power, and ground. What does any of that have to do with the MAF?
First the J&S, if you are using the mid range boost based retardation, uses a built in MAP sensor. And secondly the only thing to do with the MAF on a J&S is a a MAF limiter, which you do not need because you do not have a MAF to limit.
Like I said do not hook up anything but what I told you. You only need the knock detection and cylinder retardation, all that other stuff are just options.
just stand next to him and keep saying the same thing over and over like an annoying gnat! :D
As close to resembling a fighter jet as you can get. LOL
Hahaha,, You have to be ready for the asphalt jungle that is out there.. Well I think it doesnt look that bad considering all the gauges i have installed, I think ive done it with a good taste !!!
why do you have both the profec e-01 boost controller and the profec b spec II boost controller?
also, why not eliminate the greddy turbo timer and use the haltech for that?
looking good tho!
Miguel I still have more gauges than you! :P
Good work, but I STRONGLY reccomend you install the nipple that comes with your TiAL onto the top of the wastegate. Point it down so water doesn't get in, or it will ruin your wastegate.
And KZ9 has more then anyone I can think of :P
Show what you got Maxx, I really want to see...
Status
