- 2007 Mazdaspeed 6 Sport
What revs do you plan to set the idle at?
Because TBK Just ******* lie to be saying i had custom turbo cams when those fuckers charged for them when they are Regular FSD7 Cams, they did everything else to the head but not the cams, so If i want to make more power than car already did i need more aggressive cams since 230 degrees lift is garbage.. i can't decide what i need, i don't know if stage 2 are good with good idle power band and driveabilty or stage 2.5
I'm starting to think what i have and will have is more than enough. my idle was perfect and car pull like no other beast around. so i just might stick with them and just do the remaining mods, 505z00m im and retune the car and up the boost and that's ******* it.
Yeah i guess. what i just don't want is to have a bouncy engine and bad idle, plus in here Co2 Inspections are a PITA
Twiggy turbo cams (ones that have been fixed, and i believe they all ended up getting fixed in the end) should be bolt in and drive away. Of course cam gears is going to yield the best results for a particular application, but they should be just fine to bolt in.going for twiggy or integral stage 2+ is going to make your car idle pretty lumpy... it won't necessarily idle complete s*** like a V8 hotrod, but it'll be enough to get noticed... the emissions will suck and you're definitely going to run into those issues
the problem is, the duration of those are so high, that you're going to have to retard the intake cam far and advance the exhaust cam far so that the overlap is reduced... when that happens, you're basically setting up the engine to lose power because the piston probably won't be at TDC when this occurs
there's ways to calculate this s***... I'm sure there are calculators available on the internet to help do this all "on paper"... you need to take time with your tuner to figure this all out in theory so that you can make the right choice for the right cams
otherwise, a protractor, pencil, and paper can do this job too... I know how to look at that s*** on paper that way and LOOK at overlaps and s***
the tried and true way to remain emissions legal is to just get the JDM cams... the intake cam is european legal, while the mazdaspeed/corksport exhaust cam technically isn't... seeing as japanese emissions standards are quite similar to EEC ones, I don't think you will ever have issues with that.... idle is extremely smooth but on colder days it can get a tiny bit lumpy.... I don't think you will see that problem... with 10.5 degrees of overlap, I don't think you want to go much more than that for emissions reasons plus for boost reasons... corky bell said it best in maximum boost, it's difficult to get find good "turbo cams" and sticking with "stock cams" is the best... also 8.6mm of lift is pretty aggressive for stock cams.... many japanese street legal aftermarket cams typically have 9mm lift, FYI
the other attractive thing with the JDM cam setup is price... you are already way over budget with this s***, if you go with any aftermarket setup, it's going to cost you almost 1000 more... with the JDM s***, the base circles are exact factory, meaning they will go on and you won't have to reshim it 90% of the time... that'll save you some money and give you already a significant boost in performance... the 8.1mm lift in the FSD7 cams you have are garbage, so is the wussy overlap and duration... the JDM cams don't look like much over the FSD7 cams, but believe me, they are enough to get the job done and stay legal... I have these in my car and I always make power still at 7000rpm.... the JDM s*** are also the only cams you can bolt in and go without any cam gear tuning mess... ever twiggy cam story I hear is you have to dyno tune with cam gears.... what an expensive waste of time!
they're just plain ol' bad FS-DE 98-99 cams with bad lift and bad durationAfter Sending Juan at Hiboost an Email regarding what Head theyve install in my car and what was the info of the Cams i have, i just got an email back from Juan, and this is what it says, ill translate it to english since it was written in Spanish.
Los arboles de levas no son modificados. Estos son los que vienen de fabrica en el 626 version Japonesa.
Juan Oviedo.
The Cams you have are not modifed, Those are OEM Cams from the JDM Mazda 626 Version.
Juan Oviedo.
I have no idea what that means, if they are good, whats the spec on them since he didnt mention or sent me any info. any thoughts or info about these head and cams .. Thanks.
just be glad I saw it and went WTF and made you ask questions
yeah they are quite basic... but they are damn good for the price and what they are.... they are the ones to get if you are on a budget and worried about being legal... for sure they will bolt on with little or no shimming.... I don't know about integrals because hardly anyone has them... but seeing as lordworm says the twiggys also bolt in fine, that's also another possibility... the issue with the aftermarket s*** is, they're damn expensive when you already have major cost overruns in your project... the prospect of having to buy another 200 bucks of shims doesn't settle easy in anyone's stomachthe FSZE cams are a solid, though somewhat basic compared to the rest of your build, upgrade. I have NO idea however, if the FSZE came in the 626, or if it was just the FDSE. I'd lean toward the FSDE, but still dunno if that means they're much of an upgrade.
heres betting theMAN knows...
it helps I have the FS-ZE intake manifoldTwiggy turbo cams (ones that have been fixed, and i believe they all ended up getting fixed in the end) should be bolt in and drive away. Of course cam gears is going to yield the best results for a particular application, but they should be just fine to bolt in.
Never heard of anyone having to "dyno tune with cam gears" - hell i'm still waiting for someone to post a dyno print out of a ride with the twiggys in - afaik, most of them are sitting on shelves in garages gathering dust while people get the rest of their builds together.
The only people who really NEED to muck with cam timing are the people who bought NA or FI cams and are now wanting to run them on the other setup (only difference in the profiles was the pin location - FI had next to no overlap, NA had a truck load) - or people with NA cams who cannot deal with the high idle and lope..
Also, theres no need to shim the Twiggies (can't speak for the integrals) - as they were machined from blanks, and base circle was dialed in correctly at manufacture (they are not regrinds, so the base circle wasn't reduced). The exhaust cam has a larger base circle, but also has different lash specs, so reshimming shouldn't be neccessary. Most people have found moving the shims they already have around a bit gets them within spec.
That being said - they are pretty damned wild for turbo applications. Plenty of people make big gobs of power on the stock and JDM cam setup with a turbo strapped on - and whilst the gains with them would be nice, the reduction in driving pleasure at low RPM in traffic might not be something people want to really deal with ... :S
pretty awesome that you still make power at 7k with the JDM's...mine had the JDM cams from factory (aussie spec etc) and the power fell in a giant hole in the high 5000's....my 7k the motor was absolutely gasping for air.
it'd be nice to have actual timing specs of the twiggy cams rather than a plain duration number... that way people can see exactly what they are and what kind of overlap they really have... you think you have those numbers handy?
<rant>
it's really no secret for any sort of cam specs... any good engine builder or machinist can easily reverse engineer this s*** and find out (like what what happened with these FS-DE cams)... this is why a long time ago whoever it was up in indiana making cams (for our cars... forgot who it was) was being all so secret hush hush... I was like, **** your bulls***... major cam companies like crowler and crane actually advertise this s*** because they know that they're not perfectly made, so they encourage installers to use degree wheels to check the s***! but most people still don't know this and upcoming cam makers prey on this fact and rip people off like TBK did to miguel
</rant>
