Here's the problem. In racing, clamping power is nothing compared to longevity and heat resistance. If we're honest, the brakes on the MSP are MORE than adequate when it comes to clamping power. Its not hard to lock them up at high speeds if you stomp on them. Larger calipers only means you'll just be able to lock them up with less foot power. On the other hand, the larger pad and rotor mean that there's more surface area to dissipate heat. If you want better ONE TIME stopping performance, I suggest the following modifications:
Soft brake pads
Slotted rotors
Ultra High Performance Tires
The first two mods allow the pads and rotors to work together immediately. The slotted rotors bite into the pads, which as soft as they are, dig into the metal of the rotors. Now, with normal street tires, the braking force will overcome the coefficient of friction that the tire contact patch has on the road, and the result is a lockup. Honestly, the NUMBER ONE way to increase braking performance is to either increase your contact patch, or increase the stickiness of the rubber.
The downside to the above mods are that the softer pads don't last long to begin with and also dust A LOT, while the slotted rotors eat pads for breakfast. The tires also usually have a short shelf life too, but at least you can get other performance gains besides braking from them.
Now we get to the issue of brake balance. The brake booster in our cars is designed to provide a certain ammount of fluid to each caliper to provide the exact amount of brake pressure to the front and rears. If my memory serves me correctly, its typically a 70/30 F/R balance. By throwing big brakes up front only, you can potentially throw this balance off, and thus negatively affect the handling of the car. Mazda spent hundreds of hours and hundreds of thousands of dollars developing the right brakes for the car... Do you think you know better than them?
Honestly, if you want the best out of your brakes, get some nice ceramic pads, slotted rotors and some sticky tires.
If nothing else, this is a cosmetic upgrade...
