Wagonbacker9
- 2004 'Hoe
because what happened is that when i installed the cams, some lifters touches the cams and some have gaps between, so my mechanic told me i need to get the top part of the lifters which you can remove and get them in the thickness i need for all of them to be even do i make sense ? he took one of t he lifters off and through the bottom of the lifter with a screw driver he took the battery looking type thing of the lifter i remember its 27mm diameter but we need to measure all of them and buy them in the thickess we need in order to all of them be even with the cams, according to him all the lifter should have a gap between the cams, and some do and some dont. i believe ive heard him saying something about when the valves gets hot they close or some s*** like that..
yeah, you basically need to do a valve lash (gap between lifter and cam) adjustment. since you don't have rockers, its a lil more fun than your average pushrod engine... but yes, your explaination of how to adjust them is correct.
