What have you done to your MS3 today?
Washed and then pulled it into the garage and am halfway through my TWM Short throw shifter install. Car is getting loaded into the trailer tonight for nationals next week!
Purchased:
Mazdaspeed Replica Side Skirt Add-Ons
RE-Amemiya Replica Rear Spoiler Lip
Flex Innovations Grounding Kit (in Blue)
New Tires.
Got the itch and went ahead and had my new tires installed today, Hankook V12's in stock size. First impression is that they are definitely quieter. It's really not fair to compare the worn out stock tires to a new set. People only remember the old tire in it's last days and compare to the new tire. I have noticed less wheel spin in 2nd when getting on it and ran the car up to 100 on the parkway and it was very smooth, so I'm happy with the balance. Big O Tires did the install. Got 29,000 miles out of the stockers.
the install on that lip is more detail then most would think...i used four hands to make sure it was done perfect...make sure not to pull the 3M liner before you install, leave some nice pig tails so you can pull while on your spoiler...
Thanks for the tips.. I'll definitely do that. :)
Finished installing alarm/remote starter with window automation. Everything works great, but spent about 8 hours installing it.
how much did that run you? and which kit was it?
It's a DEI Python 881XP 2-Way Security and Remote Start System. The alarm is a couple years old, I got it from a buddy all I had it do was remove it from his vehicle and it was mine. All I spent was $45 for the ignition immobilizer.
Got my rear fenders rolled and TRZ Poly Dogbone installed. No more tires rubbing, and shifting is now a pleasure, even the spirited 2-3 shift. The vibes are noticeable, and I can see why so many folks complain about them. But I personally don't mind.
