rally armor mud flap install question
pcpower
can the mud flaps be installed simply by turning the wheels left and right as necessary in order to leave enough space to use a screwdriver? or rather do the wheels need to be taken off in order to have that extra room to get all the screws in properly.
anyone install a set and have an estimate how long it took u?
thx
thx
Print off color instructions (easier to read) from RallyArmor.com <-Click it.
And yes, you do not need to take off the front wheels, but you will need to take off the rears.
Probably takes an hour to do the install.
for the front flaps, turning the wheel is all you need to do. the fronts are the easiest part and only took me 5 minutes to do. The lining itself is a little tricky to get out, if you're doing this for the first time but it bends easily so don't be afraid about ripping it or something.
as for the back you must take the wheels off in order to install the flaps. it makes things a lot easier.
over all, it took 20 minutes for me to do the install.
