xDJ DUBx's 03.5 Pure White LX-T
nope, neither will I.....
but, i can still throw my little ones that fit inside the fog deletes.
I can get you a set if you want Dub
what do you mean by mount it further back???? the bracket itself or the blazers? as far as the blazers go you cant push them back any further due to the long fog light housing in the back hitting the car frame support next to the radiator, i swear to god you cant win with these flipping things (pissed)
well if the back of the fog is hitting a rad support, either find a different location, use a shorter fog, or if possible cut a relief in the core support.
I had to make room for my FMIC tubing, so I cut, then folded back a piece of the core that stuck out past the subframe connector... structurally it did (next to?) nothing... and it was in my way. problem solved!
FMIC or fogs.............oh the decisions!!!! Shall I help persuade you? Fogs don't add as much WHP as an FMIC does, though it's close :D
J, are you using HID's? The HID bulbs stick an easy inch if not more further out of the back than the bulbs that came with it
Damn, I love your setup and my setup, sucks that you can't have fmic and fogs in that space.
Sure dude, if the deal goes through, I'll do those little rectangle fogs in the deletes.
Wait, actually, I'll probably do mazdaspeedo35's fog setup, those are SEXY
yea actually iam 8000 ks of pure brightness lol the bulbs that came with the blazers are actually shorter than the hids you right !!! which is probably the reason of my many problems
