which bov to choose?
phantomspeed
mazdaspeed 3 2009
hey guys i had a question i was looking at the rkm bpv and wanted to know if the part as goodalso is it just a direct bolt on or do i have to install the flange i also wanted to know how it measures up to the forge bpv im knida new with the car its a 09 speed three so any help would be appreciated thanks guys
the RKM is a fine kit. the forge is our best selling unit and for a car thats stock or even with the most bolt ons its a great performing setup. the interchangability of the springs and shims is a nice feature for when you decide to run more boost.
i dont like the rkm. it was originally marketed as 'identical to genuine HKS valve'. Then later it was found out that it was not....not a fan of knock offs.
I've seriously had about every valve out there... My favorite was the HKS and Turbosmart compact dual port (what I've ran now forever). Only reason I traded the HKS in was because the recirc line would not fit right with my FMIC setup and I got tired of running VTA. SU/turbosmart also has a new/cheaper bpv. As far as value....forge and the new TS one seem to be where it's at. I'm personally not a fan of the forge sound, but it does function well and is a good value. From what I've seen the new TS one sounds pretty much like stock, maybe a little louder/crisper blow off noise.
Not a lot of people seem to like the Forge sound. I was hoping for the Forge "ping" and I don't have it at all. It's is a GREAT valve though and out performs the TurboXS I had before.
i would check out the new turbosmart bpv if i didnt already blow $330 dollars on the turbosmart dual port only to run it fully recirc all the time.(hand)
I had the turbo smart Dual port Bov and was running 50/50 and my car felt awesome, but i recently just installed a Greddy type RS and my car feels a lot better!! oh and no more back firing!! haa
i have the hks and really like it but it's true that on stock setup it's tough to fit correctly with recirc. hose - i haven't seen a kit that has all the parts just right yet! you need the flange that comes w/the cpe kit - you need pg garage's 1.25" recirc. fitting, and you need a silicone hose of your own that will not kink
the forge if im not misaken is a direct bolt on unit i am leaning twords the forge anybody else got any other ideas to sway my opinon lol
Like said before Turbosmart BPV. Same price but no PING sound it sounds like a BOV but with out the "rich" results of having on.
yea, thats the only reason i got mine in full recirc is because of the backfiring. other than that, it works just fine.
I'm a fan of turbosmart dual port as well. Not only for its performance, but I think it looks the best out of the others in the engine bay.
not to hijack the OP question buy if i got the turbosmart bpv. that means when i s*** at high rpms i wont backfire?? i love doing that haha. shifting from 2nd to 3rd sometimes i hear a pop and 1st to 2nd
