looking for the how to install a test pipe thread, can someone help me
I did the search and didn't see the how to install like I found for the catch can and all taht other stuff. ANyone got the post on how to intall a test pipe.
its easy. just get some PB blaster/WD40 and spray the bolts oon the OEM midpipe connecting to the DP and CBE.
unscrew the bolts, take the Midpipe out, put the TP in and tighten all bolts
Did you take those braces out? and like I said, I got the pipe used and didn't get any bolts, can I use stock hardware, or what do I need to pick up?
Did you reuse your stock bolts, or did you have the bolts in with the kit?
if the bolts from stock fit they should work right?
the bolts connecting the down pipe worked, the bolts that connect the test pipe to the exhaust I replaced with 2 M10 1.25 thread that were 70mm long. I could have used a little shorter one, maybe like a 50. No nuts or nothing were needed.
