Wheel and Tire Help
dsurls
Guys, I'm very new to this wheel upgrade stuff, and I could sure use some help with a wheel and tire decision ....
Just recently bought a 2003 Mazda6 which has Chevy Monte Carlo SS wheels (don't ask!) and performance tires. (18x7, 5x115, 52mm offset, and 225/40r18 tires).
The tires need to be replaced, so I ordered some more 225/40r18 tires from Discount Tire Direct at a good price, and took them to a local Discount Tire store for installation. To my surprise, because the rims were not the spec bolt pattern for a Mazda6 (5x115 instead of the spec 5x114.3), the store would not install the tires and mount the wheels on the car.
So, in order to avoid future hassles with trying to find stores which will rotate/balance, etc., I'm looking into getting new wheels with the proper bolt pattern and try to sell the Chevy rims.
Since I've already bought the 225/40r18 tires, I'm trying to find some 18" wheels to match. Based on the sticky thread here about wheel/tire sizes, I'm a little leery about going with the aftermarket 18x7.5, 45mm wheels available at Discount Tire (because the offset falls outside the range for the 7.5 width with this tire size -- don't want them to rub). Are my concerns valid?
Is the clearance the same for all Mazda6 model years? Are there factory 18" OEM Mazda wheels for other models that will fit with these tires without rubbing? (The sticky thread indicated the RX-8s rubbed on some Mazda6 vehicles with this tire size.) Maybe a newer year 18" Mazda6 rim? Recommendations for places of purchasing them?
Not interested in doing any of the fender rolling, dropping height, etc. And not looking to spend a tremendous amount of cash.
Thanks for any advice you can give!
Plus wheel size Newbie,
David
Pic of existing Chevy rims
Pic attached.
um... idn about you... but that looks too VDUB ish for my liking.
and a 7 wide 48 offset is only going to set you out another 15mm over stock. and another 4mm further out then what you have now. Hell 4mm is like nothing.
EDIT: Sorry, that was for a 7inch wide rim.
so... an extra 10mm over what you have now. can you spare 10mm?
I have no idea -- that's what I was hoping you guys might be able to help me out with!
(BTW, it's stock suspension, no fenders rolled, etc.)
David
RX-8 wheels from 2004-2008 (five-spoke) look especially good on a Mazda6. It's a good fit for a 225 tire, if a wee bit too wide at 8" wide. (I have 18x8 wheels on my MS6 with that size tire). I don't think you should not have any rubbing problems unless you drop the car with lowering springs, but please, others with experience with a non-Speed6 please chime in (I did notice that my '03 6s was a bit lower than my '06 MS6).
The RX-8 wheel from 2009 (the sorta 10-spoke style) should also fit. (It's what I have on my MS6).
Expect to pay $400-600 for a decent set of RX-8 wheels, plus shipping.
