yea. i see grease splattered on the underside directly above the joint the boots are on
ok bled all 4 tonight after work. all seems well. its a b**** to remember how something felt before it messed up and after you fixed it... so will see.
I also filled up my coolant way too much lol.
Are the boots torn/split or is it just the clamp not holding it in? You can replace just the clamp...replacing the boot is quite a bit more of a pita. I and not even sure protege axles come apart in which case you need a special tool to do a boot....aka replace the whole axle
should have installed speed bleeders when doing this....makes life soooooooooo much easier.
I ordered a Kenwood KDC-MP442U head unit to replace my crapped out stock KDC-MP919. I'm hoping that because it's another Kenwood unit, the new one should be a simple plug and play installation using the same connectors.
A man of few words, your wisdom speaks volumes.
Next time try to give me an abridged answer, yeah? LOL
Thanks! (thumb)
lol. well from my experience, most/all of the kenwoods have the same connector in the back. so i would assume that it should be plug and play..
Awesome. I assumed the same, but the fact that there is a ~6 year diffference between the two models, I thought there was a chance they may have changed things. Oh well, even if they did, it probably won't complicate the install all that much.
nah. those are really easy to install.. i can have mine out in something like 5 mins. lol.
what sucked then still sucks now LOL. only kidding.(rofl2)
Installed the JDP carbon fiber front splitter.
I also installed Forcefeds carbon fiber radio bezel a week or two back. I wanted to post a picture so he could see what it looks like installed :)
Here's the splitter...
both look amazing. i wish i could get a splitter, but with the bad roads, and the winter time it would be like a plow.
