Am I missing something?
koston33
Ok so the last couple hard drives I have taken feel like I'm not getting all my power. I don't know if its a hickup or a hesitation but on WOT im not really feeling the power I've felt a couple weeks ago. Mods are ms cai, forge bpv, and cobb ap stage 1+. I'm hitting around 20lbs of boost at WOT and my afr is 9.3. Why the hesitation. Any ideas?
ya i know but that's not going to cause me to stutter or hesitate is it. I know its not the lag.
20lbs of boost also seems like a lot. I'm on the same map and same mods and get 18lbs steady with little to no spikes above 20lbs. Maybe its your BPV setup? What spring/shims are you running?
You should really upgrade your IC if you're going to continue to push that much boost.
Reminds me, SU's "improved" TMIC supposedly was finished today, must call to get mine replaced!!
Does everyone get theirs replaced circle ??? My brackets are fine but it still has the hose kink like all other TMIC's.
