yeah i used to have to get my g/f to bring it from MD when she lived there...can only get it in non emmisions counties here.
Other option is to mix your own just using alcohol instead
I have about 3 gallons of Apex Washer fluid - I just don't know it's methanol/additive content. After searching around a bit it seems it will suffice it's just unlikely it is the ideal mixture. I see I can order some pre-mix from Snow Performance though (49/51 methanol/water) for like $30.
Anyhow, I just ordered a new, smaller nozzle for the kit and an aluminum bung for my intake pipe. Hopefully I will have everything and can start the install sometime next week.
Never understood how snow charges that much for that stuff.
Like I said go alcohol if you can't get the windsheild washer stuff...homedepot/lowes will have a gallon of denatured alcohol and then grab a gallon of distilled water...50/50 mix and you have two gallons worth of mix for about $10
true that.....it should be in the paint section with thinner and other crap
car is gutted except for drivers seat and back part of the rear seats.
car idles at 700 or so so im fine. oil change (time to do anyways) and plug change tomorrow
I was going to start the teardown tommorrow, but just got done tonight...all that is left is unbolting the tranny and dropping it out the bottom...
don't ya just hate that......you start thinking about something and ya can't wait till it's done.....i know how ya feel....sorta
Exactly...I wanted to do it tommorrow, but really just wanted to get it done...I would of finished getting the starter off, but I didn't have the available light to finish the job...my little flashlight ran out of charge...
nights like that is why i love my dual 500watt halogen work light...lights shti up better than normal day light......but it's just hot as hell
Yea...I was in the dark driveway with a little tiny flashlight...that is all the light I had...the hardest part was finding where things were in the dark...
yeah....when i had to pull the oil pan on the truck.....i did it all by feel the 2nd time and in the dark and put it back together in the dark cause i already knew where everything was from the first go around the week before...
autozone gave me the wrong pick up tube
shud your pie hole.......you know you'll love it when you get to enjoy it....
if you are that unhappy i'll gladly take that s*** off your hands
So, when driving home, i happened on some plastic blowing around the road. I hit it, and didnt see it come out the back. I just figured it was stuck in the grill, so i just continued home, cause I didnt want to pull over on the interstate. Well... here is what i found. (dont mind the rust... stupid MI)
How did it stick to the exhaust at 70mph? Anyways, now it smells like burnt plastic. It will probably for a while.
Oh and i found that funny rattle i have been hearing.
Rust anybody?
