Here are your options. For your rear struts, you're screwed with aftermarket if you want to keep your stock springs. Stock MSP rear struts have a higher spring perch location, and a shorter spring height because of it. This means you can't buy a regular Protege strut and use the MSP spring, you also can't buy a regular Protege spring and use it with the stock MSP strut. You either go OEM MSP replacement parts, regular Protege parts, or full coilovers.
1. Get stock replacement struts from Mazda. Very expensive and you're looking at spending close to $900 shipped from onlinemazdaparts.com.
2. Get the Tokico suspension kit for the Mazda Protege. These come with struts and lowering springs together. They will lower your MSP about 1/2" more than stock and be slightly stiffer. If you want to stick with non-adjustible struts, you can get the HPK247, which comes with Blue struts similar to stock. If you want adjustible, you can get ILK248, which comes with the adjustible Tokico Illumina struts.
3. Tokico Blue/Illumina struts paired with Ground Control coilovers
4. Full coilover system
For daily driving, your best bet will likely be #2 for the money.
Also, if you do replace your struts, any chance you could send me your blown stockers for the cost of shipping?
