Mazdaspeed3 Dyno Comparisons
413 ft-lbs of Torque! Most for just bolt-ons!
Pretty awesome, hunh?
Alright, that's just a fluke that I noticed when I accidently left the bottom axis on Speed instead of engine Speed. The second graph shows a more legitimate result with the red lines being a stock baseline I had done awhile ago and the blue lines being a dyno I had done the other day with the Nano and a mid-pipe. I am not happy with the way the AFRs tanked on these dynoes and don't know if they are truly representative.
The speed 3 definitely has a split personality based on weather and humidity.
I really enjoy the fall and winter here in florida, as the car really shines then.
Car: 2009 Mazdaspeed 3
Modifications- Cobb ATR professionally tuned by Fluid Motorsports
Gas: 93 octane
Ambient Temp measured by Dynojet
Run# 1- 100.52
Run# 3- 102.02
Humidity measured by Dynojet
22% both runs
Intake air temps:
Run 1 - 102.2f
Run 3 - 105.8f
Boost:
Run 1 ~13psi
Run 3 ~17psi tapering off to 14 psi @ 5600rpm and 10.5 @ 6756rpm
And Now the Stock Dyno!!
HORSEPOWER GRAPH:
RPM-----Stock Power-----Tuned Power-----Gains
4.0k--------178.6------------199.5---------20.9
4.5k--------194.7------------238.4---------43.7
5.0k--------214.7------------246.9---------32.2
5.5k--------235.8------------253-----------17.2
6.0k--------186.1------------240.5---------54.4
6.5k--------125.9------------197.1---------67.2
TORQUE GRAPH:
RPM-----Stock Torque-----Tuned Torque-----Gains
4.0k--------231.9-------------261.7----------29.8
4.5k--------227.3-------------278.2----------50.9
5.0k--------225.6-------------259.3----------33.7
5.5k--------225.2-------------241.6----------16.4
6.0k--------162.9-------------210.5----------47.6
6.5k--------101.7-------------159.3----------57.6
I just got my Dyno done yesterday. 1st Pull was stock except with COBB SF Intake, 2nd pull was with new parts installed : Desno ITV22 plugs, TXS RB & DP combo, COBB TIP, and AP Stage 1+SF 91. Is it odd that i reach peak HP near 4500 RPM and stays there till about 6500? I have large noticeable gains across the mid band but peak is only about 5hp gain. Also, does the torque curve look normal, i have huge gains across the mid band but tapers off pretty early? For stock (relatively) on the first dyno I had allot more power than I thought i did. Thanks guys for all input and feedback!
garage_attachment.php
I have protuned a few full intake and exhausts 08' speed3' making 285hp/300ish TQ. I will post them when I get back to the dyno on Monday. I believe I even have one with a TMIC at just over 300hp.
EB Turbo
Tri-Point Engineering
RX8, Speed3/6 Cobb Protuner
