Huh? You don't have to remove the adjustment knobs to install the rear shocks. It does take some contorting, particularly on the passenger side to get your hand to the knob though.
I didn't install the adjuster knobs when I installed the shocks.
They come already installed on the shocks. At least mine did.
mine came in a bag too. I keep them in my ashtray now
1) Compress the spring perch until max rebound.
2) Attach knuckle. (Is that the lower shock mount point?)
3) Rotate shock body clockwise until resistance is felt. Tighten set nut.
CHIEFSMS3 said:here is how I did the rear. I installed the spring and the top of the shock. With the car supported with a jack stand I let the jack pressure off of the spring so it was at max rebound(hanging). Then I twisted the shock adjustment down till the holes lined up and installed the bolt. Then I twisted the shock body 10 full(360 degree) turns up to set the preload. It seems to be working alright for me.
	I don't have Popeye forearms, but unless I unpop every little tab and snap, I can't get in there. I was able to drop the knob into the hole, but I can't get it to grab onto the adjustment threads. I think there is a sheet of metal on the side which may force it to go down the hole at an angle, instead of straight down. The thing was about to cut my forearm off, so I gave up. I hope the extenders help.
...On a side note, because of the access through the jack compartment and that little tab that pops out on the right for (light access?) theres no need for the extenders.
BTW, for those interested I changed my dampening settings yesterday to 12F/16R (40%/53%) and so far i like it much better. Before I was running 9F/12R (30%/40%) and lately they have been feeling a bit squishy to me. The temp has gone up around here too. We've had a couple 80* days which may have something to do with it, who knows.
