Installed 626 Mani and coolant tank
JCell
BEETEK!
2014 Genesis Coupe R-Spec
There should be an oil catch can as well, but it's delayed for the time being
My experience with the 626 Mani install
-stock fuel rail does not fit the 626 mani, had to modify the black spacers to make it fit
-needed 626 EGR(Ken warned me but i didnt listen), so now i have a cel
-I added vacuum ports to avoid using that many t's, highly recommend other people to do this
-im now running 12.5 AFR at WOT, while b4 this i was at 10.5 @ WOT.... should i be worried? idle and cruise AFR are still the same
Here are the pics, enjoy
Edit: the last pic is how i got it
isnt it? thank you sir for the good deal, took me a while to install it to make it nice and smooth
well you added a manifold that has a higher flow than stock.. of course your afrs are gonna be different.
but by 2 points? that seems like a lot.
im not complaining too much though, pulls really nice :)
the thing is my car still uses the unflashed msp ecu.... no boost control, no fuel controller, nothing
good job man, looks clean... you know I gotta go on a test drive now, right??
.. NO boost controller or anything?? not even a manual boost controller?? you could and should at least get a RRFPR.. for fuel control.. or buy an mpi?
you know it lil homie... im trying to keep up with the red beast!!!!
nope, running 7.5 psi with no problems, so i havent thought about it too much
im planning on gettin an AFC soon, but i wanna make sure that this new AFR is because of the manifold, and not something else
it seems to make the most sense... more air, def changes the stoich of the afr.
looks nice!! hmm we have a lot of the same mods (appearance) under the hood lol
so some light on my lean problem..... everytime i go into boost. my fuel pres drops to about 23psi..... from 35
