Weird sound when pushing in clutch and letting it out
2001 Mazda MP3
Ok, so when the car is cold, i push in the clutch, and it makes like a bird chirping noise, and let it out and it does the same thing, just as push it in, and right as you let it out.
But when it warms up its not as noticable, and it also does it going over speed bumps it makes the same noise...
jesus do a god damn search for once,
its clearly the problem with your bose headunit which people were having recalls for, idiot.
NOTTTT..
i have no idea but wondering what it could possibly be so im subbing.
sorry for the threadjack
In a quiet place try this:Try depressing and releasing the clutch with the engine off, trans in neutral. Then repeat with engine on. Then again with engaging gears. I have a similar sound and think it is in the clutch pedal mechanism, but not in the motor nor trans, as mine does it consistently under all of the above. Haven't crawled up under the dash yet to isolate it. Hope you find your cause.
If you have aftermarket mounts it will be the throwout bearing or transmission noise. This is normal. Otherwise I do not know what it could be.
with the trz rear mm and trz tranny mount the clutch chatter is maddening. i sit at stoplights with the clutch in so i dont have to listen to it haha.
its not a grinding type noise, or a clicking, is literaly sounds like a bird chirping i'll try to get a sound clip next time it does it
I know it makes noise... All the trans mounts do. My advive is not to sit with the clutch in all the time. It will greatly reduce the life of the throwout bearing.
Just let your car sound like the bad ass machine it wants to be !!
(iagree) Very bad driving habit!
