Check with your local track before running R compound tires. Certain tracks (like VIR), will not allow anyone in novice or beginner classes to run R comp's, as they are extremely dangerous at the limit.
Unlike street tires, R comps will tend to grip almost right to the limit, then suddenly let go..while street tires will tend to complain and groan as you approach the limit, giving you more feedback. Additionally to make full use out of R comp's, you'll need...
1) Some sort of harness or system to keep you restrained in your seat. (Cg-lock will help, but man you won't believe how hard an R comp can grip and throw you around in the car)
2) Suspension modifications
3) Track Brake Pads
If you do not have a lot of track experience, I'd recommend going with something like a Falken RT615 or Hankook Z212 instead...which are street tires with excellent dry grip. (The falken outdoes the Hankook in terms of sidewalls and dry grip, but loses in wet traction).
