So, I had to take the door panel off and pull down the clear plastic inside (I hate that black stuff they use) and take a close look at the electrical setup in there. I cleen the connection that connects the lock cyclinder to the door switch, and that did nothing new. As I was futsing with it I got it to work some times. So I removed the whole door handle and cyclinder from the door. What I found was that on the back of the lock cyclinder is a switch that snaps into place and has a little cut out to meet up with a keyed post on the back of the lock. When you turn the key it's suppose to activate the switch. Mine wasn't working right. When I pressed down on the device it worked just fie but when I let it go, nothing. I figured that there must be something to do with the pressure on it so... I took masking tape (yes I fixed my locks with masking tape) and placed a tiny little peice inside the switch where the post from the lock goes in. I cut it carefully to fit the shape and pressed it in with a tweezers. When I put it all back together the part clipped on much tighter and Wham, working auto door lock on the passenger side.
