After 3 days, busted up knuckles, bruised elbows and back, and countless unforeseen problems.......its finished (nana). I installed the exedy stage1 clutch, fidzanza flywheel, SS clutch line, new rear main seal, pilot bearing and throw out bearing, and two new axle seals. And the end result is a awesome feeling car as well as deep oil stained hands that I still can't scrub clean. And thanks to LinuxRacer about mentioning the rear main seal, since it was starting to leak a tiny bit at the bottom when I took off the flywheel. Also the throw out bearing was done for when I took it out cause it was loose and making a clicking noise.
