Where did you guys get your flange for your BOV/BPV
MS3MB
2008 MS3
So I have a Forge BPV and I need a flange and I was just wondering where you got yours?
Its my friends old BPV an its needs a flange sooo I figured other people ran into the same problem and wondered where they got theres and if they had any problems with it
hmm, what car was it from? I'm not aware of a flange for a Forge BPV since Forge makes a direct fit BPV for our cars.
yeah, but forge makes valves for other cars...what car did your friend drive?
if you have his old ms3 forge valve, then you won't need a flange.
if you need a flange, then you can find one at pg or su
The A4 uses a valve with a 25mm hose connection for the discharge and inlet. One of which is integrated into the body of the valve, no way to add a flange without welding. And you would still need a 28mm outlet port.
You will probably be better off selling that on a VW or Audi board and getting a ready made MS specific valve.
i'm not making fun. i know a female named ryan. i have a friend named scott, who i call stacy.
unfortunately, i also know a guy named loren and a guy named kelly.
and I know your name isn't really "john" :) Where did you cook this screen name up from?
