My data logs
Trader
2008.5 MS3 - MSCAI2 as SRI,Cobb AP, CPE MM
Here are some of my logs.
All of these are stock logs. NO MODS at all.
I really noticed that the boost drops when the ambient temps drop.
The logs are the following from left to right:
left = Stock 3rd & 4th - 20 degrees ambient
Stock 4th 36 degrees
Stock 4th 42 degrees
Stock 4th 50 degrees
Right = Stock 4th & 5th 63 degrees
Here are some 3rd gear pulls:
All stock
Left = Stock 3rd 30 deg
3rd 41 deg
3rd 4th 42 deg
3rd 50 deg
Right = stock fuel trims
The following logs are with the MSCAI2 with air straighteners. No other mods.
I noticed I am holding boost much better now with just the intake. Even though these were done in cold weather. Still running rich though. Next will be the Cobb AP to fix that!!
Very interesting that I am getting 15 to 16 psi boost when the cars struggled to get boost with the stock air box.
I have noticed my fuel trims shot up after the intake. No logs but I am getting the following for my LTFT:
idle = 4 to 6
Part throttle = 7.0
Engine breaking = 7.8
Medium throttle & WOT = 10.2
Left log = MSCAI2 3rd gear 37 degrees
MSCAI2 4th 32 deg
MSCAI2 4th 38 deg
Right log = MSCAI2 4th 38 deg
I just flashed the AP MSCAI2 (cali.) V1.03 93 octane map. So when the fuel trims settle I will post comparison logs for this map in a couple days.
Screw the pedal position... Absolute throttle is enough.... If your comparing logs at different temperatures, use the BAT (Boost Air Temp). This is temp at the MAP, and this is what the car reacts to ....
I have a theory that the ecu detunes when the IAT is low. Because the BAT were the same for some of these and I got different results.
Well it kinda uses both, but mainly the BAT. In the winter months, IAT influences a lot. Not quite in the hot months though. Have you tried heatsoaking to about BAT 120 and logging? You'd be suprised....
Make sure you log fuel pressure as well. I was unpleasantly surprised the first time I saw a log of mine with the fuel pressure...dropped to around 1100 at one point :\
great logs trader and congrats on the ap. You lose boost in the cold because the ecu is just trying to meet torque targets not boost targets. You need less boost to make the same power in cold weather.
Dread, Auto was refering to a junk post that just got deleted.
Just ran the data logs with the AP. All I can say is WOW!!!. The car is freaken fast. I am at work now but will post them as soon as I get home.
Ok here are some logs with the MSCAI and Cobb AP map MSCAI2 V1.03 93 octane. No other mods.
I drove the car for about 120 miles before going WOT. I did notice a little stumble here and there in partial throttle earlier at about 15 to 20 miles after the flash, but that has since disappeared. I guess the car just needed to get used to the new map and adjust the trims. My LTFT have stabilized. And are the following:
Idle = +6
Engine coasting = +7
Light throttle = +7.8
Medium throttle/WOT = 9.2
Still running a little lean, and they are close to what they were before the flash. It was about 32 degrees when I did these logs, so hopefully they will go down a little when the temps warm up here.
Running stock plugs for now. About to order the Denso's.
Anyways the AP really opened the car up. Definitely felt a big difference with this map. 50% throttle feels like WOT stock. Wheel hop is definately a problem now. Good thing I have a CP-E motor mount sitting in my garage waiting to be installed this weekend. :)
I did not log to redline because this is my first time going WOT and I wanted to see these maps to make sure everything looked good before taking it to redline. But the car pulled really hard the whole way to when I let off.
Not seeing any substantial Knock retard. Fuel pressure looks good. AFR between 11.8 & 12.8. May be a little lean for my taste. Way different than the stock map.
Both logs below are 3rd gear logs
You can see that cobb really opened up the throttle plate with these maps I am getting 80% at WOT when before I was lucky to get 50%.
The wastegate solenoid is now keeping boost up when before it would fall flat on its face on the stock settings when it was this cold. You can see a comparison log of my stock 3rd gear pull at 30 deg on my second post.
looks good. that a/f ratio should smooth out once you start driving more at WOT more often. I'm not sure why you are getting spikes like that. Do you have the air straightener
I did another log today.
This one is 3rd gear. Ambient temps at 65 deg.
My fuel pressure is dropping to 1400. It looks like it is only doing this at the boost spike.
Still running only a MSCAI and AP V1.03 93 octane.
Looks like if I do any more mods I need to get a fuel pump, or should I just get it now?
Any updated info, or impressions of your setup ?
It feels a lot faster than stock. I get a little hesitation sometimes (random) only at 3000 to 3500 rpm. And my LTFT at wot are at +8 to +9. Other than that no complaints.
i have the same mods as you w same map but i don't have thea dashhawk to do these logs. i use the ap to monitor. WOT my AFR are sometimes 9.3 9.4 I too get a little hesitation sometimes @ same RPM ,i agree the car feels way faster than stock ..... guess my next mods are going to be denso sparkplugs,fuel pump internals and gauges "boost, afr"
