want to find a good deal on rims?
madvillian
Mazdaspeed3
http://forums.nasioc.com/forums/forumdisplay.php?f=152
if you're looking around, keep your eyes peeled on those pages, theres new ones posted every hour or so, there are a lot more people on there than here.
you have to watch because most scoobys are 5x114.3 and some are 5x100 and for hub bores!.= but there a lot of perfect fitments and great deals! thought id post up for those to havent looked.
if anyone would like me to contact the seller on the forum (so you dont have to become a member) with your information so they can contact you, let me know!
Cool. Thanks. I registered. A lot of volks and most are at good prices.
hub rings!
5x114.3, and as far as width/offset go, depends on how much balls you have!
Dude, hub rings aren't going to do jack for you if you're trying to fit wheels with a smaller hub bore onto hubs with a bigger bore requirement...
You'll need someone to machine the wheels to the correct bore size.
lawl! Unless you use Bizarro hub rings, which fit smaller bore wheels on larger hubs.
So yes, kids, before you consider trolling other make's forums for good deals, know the hub bore, not only the lug pattern.
*Most* aftermarket wheels will have a larger centerbore anyway.
While many do, a lot of the wheels marketed towards Subarus have the 56.1 mm bore size (Rotas particularly come to mind), and it's definitely something that you need to be aware of when looking at wheels being sold on a Subaru forum...
would any wheel that came off a RSX "fit" on the ms3, as far as hub bore? i understand about lug pattern and what offsets that work, and which ones can be "made" to work
RSX are 64.1 hub bore. Like I said before, most aftermarket wheels will have a larger center bore anyway.
