Wastegate13
- 08.5 CWP MS3 GT
There is a GB going on the other forum. Got mine for 160 shipped, took about 5 days to get them in.
Hey I just ordered sportlines. Where can I get the SPC camber arms? How much do they run?
when I ordered my BC's I got both SPC arms for about $100-buy one get one free with s tr ee tu ni t at the time
Which forum Wastegate?
I just found the GB Wastegate was talking about. The GB post said it expired long ago but the coupon code for the $160 shipped still works.
Just check the other mazda 3 forums out there..........(sssh)
Thanks fellas you been alot of help. Whats that coupon code btw?
no way, eibach sportlines are SUPER low, they dont make them for the mazdaspeed3, eibach pro kits are similar to cobbs. i had the sportlines on my mazda3 and i was at -2.8 or so in the rear.
Did you take out just the upper ring from the rears? I've been waiting for my springs to settle before getting an alignment too. I'm worried that the rear camber is going to be too much and I'll have to end up getting the SPC's as well.
So you ended up with -3.5* of camber in the rear? I've guessed that mine is sitting around -2.5* to -3*.
Anybody know what a good "performance" alignment for the MS3 would be? I don't know about you madvillian but I don't mind running an aggressive alignment, as long as it doesn't end up burning through the inside of the tires too quickly.
This is what I would consider to be a great "performance" alignment:
-2.5 degrees front camber (pretty much impossible without aftermarket camber correction)
~1/16th-1/8th" TOTAL toe OUT in the front (closer to 1/16th for better tire wear, closer to 1/8th for more aggressive turn-in)
-1.5 degrees rear camber
ZERO TOTAL toe in the rear
That being said, if you're not using front camber correction I'd put the rear camber at no more negative than the front, and use the same toe settings as above.
So what's a good alignment spec for DD and some fun without a lot of tire wear?This is what I would consider to be a great "performance" alignment:
