What kind/brand of oil do you use?
In regards to comparing a big domestic V8 to the 2.3 and oil viscosity, one issue would be bearing clearances. The V8 is going to have greater bearing clearances so you would want to run a thicker oil. Imagine as your motor is running, the only thing between the bearings in your rods and crank journals is this pressurized film of oil. Too thin and it might not protect the bearings when you zing the motor or worse yet, LUG the motor. Low RPM is lower oil pressure and high load is more "squeeze" between journals and bearings. Not a good combination.
In addition, most of those older V8 motors ran flat tappet cams and sled fulcrum rockers. To combat wear in these areas, you want an oil higher in ZDDP, which is one lubricant that helps prevent wear (Zinc dithiophosphates ). Lots of guys running flat tappet cams run Rotella oils which are high in ZDDP. Problem is this stuff plugs up catalytic converters more quickly.
Modern oils have a lot less ZDDP than they used to for this reason. You can add ZDDP to your oil and help reduce wear, but it's possible it will plug up your cats sooner. It's an eye and skin irritant too. I think STP makes an additive as does Crane and Comp cams. Check out Valvoline racing oil at NAPA. Right on the box it says Not Legal for Street use. This is due to the high levels of ZDDP. Got a case of 10W40 full synth sitting in my garage and thinking of giving it to my neighbor who has a 70's GTO.
Personally I like either full synth Mobil 1 or Valvoline and that's what I'll run in my MS3 eventually. Also have ran Royal purple but it's pricey. Amsoil is also very good but best way to get it is to become a distributor yourself, and sell to your friends. Used to do that too.
In contrast, local race engine builder swears synthetic is a waste of money. He always recommends mineral based oil and change it every 3K. They don't even like to run synth in differentials or transmissions.
Never used synthetic and I doubt I ever will. I would consider Amsoil if it came down to it.
Regular changes of Quaker State have served me well over the many years.
word... as long as you change it often enough it won't make much of a difference in the long run
Is royal purple 5w 40 a good oil to use? My buddy offered me to take 6 quarts since he will be going to mobil one. Right now I use mobil 1 10w 30
Engine builders sentiments exactly. I believe he also said in regards to synthetic oils "all it is mostly is runnier" which while not a technical description is still understandable.
So all that stuff about it being more heat resistant and less susceptible to breakdown due to heat isn't true?
I wouldn't dispute their claims, but it's likely irrelevant if you change your "inferior" mineral oil before it can have much of an impact. I'll still run synthetic personally.
Gotcha. My main reason for running synthetic is keeping temps down since this is a FI car. I am not interested in extended oil change intervals.
I've heard Fram sucks too. Could start a whole thread on what brand oil filter do you use. Purolator, Hastings, Mobil 1? These cars take a cartridge filter and I have not looked into them yet. Anybody care to hijack?
ducky, your owneres manual says to use 5W30 so if you use Castrol or Pennzoil 5W30 every 7,500 miles or six months, whichever comes first, you'll be just fine, assuming you don't race or drive under "harsh" conditions.
You can switch to synthetic oil and/or change oil more frequently if it gives you peace of mind but that will cost you many hundreds of dollars more over the life of the car and the only benefit you will see is possibly a very slight increase in fuel economy (synthetic oil), nowhere near enough to make up the added cost. Some will claim you engine will last longer but there have been no documented studies that I am aware of that have proven this. In fact, the only documented study I've seen showed no measureable difference in wear on internal engine components.
This may be overlooked by some but probably the best thing you can do for you car is to let it idle for a minute or so before shutting it down. The owners manual mentions this is sometimes necessary in order to allow things to cool down a bit.
I'm actually having trouble finding better filters. I may order some from Ken when I go spin on.
Just ordered the spin-on from the Beasts in Florida. I will now be able to hunt for more generic premium filters, such as K&N gold. Too bad I just changed mine on Sunday...
I use 6qts Amsoil full synthetic (5w-30) every 3k miles and car runs great@25.5k miles. Where in our owner’s manual does it state using other oils such as (5w-40) is okay?? I've read the whole thing and don't recall seeing anything about that. Might be grounds for a warranty dismissal if it came down to it, I would be weary. Sounds like we got a bunch of people in here smarter than the engineers that created this car....
Might be, but then again they'd have to prove it as long as you haven't admitted it. Where do you buy your Amsoil?
I believe the Mazda 3 MPS manual in Europe/Japan says 5w40 is fine. I think we get 5w30 recommended due to fuel economy and emissions.
I use 6qts Amsoil full synthetic (5w-30) every 3k miles and car runs great@25.5k miles. Where in our owners manual does it state using other oils such as (5w-40) is okay?? I've read the whole thing and don't recall seeing anything about that. Might be grounds for a warranty dismissal if it came down to it, I would be weary. Sounds like we got a bunch of people in here smarter than the engineers that created this car....
why do you change it every 3! Yikes I was changing mine every 5, and still felt bad about it. During the winters months I may not change it till every 10k depending on some OA results. But during the summer when I track the car it will be 5k
