Afc V3 is now installed with the supermap for now..and to be honest, I don't feel any difference!! If I look at my wideband, I especially don't see the Afc kick the car into open loop at 1.1psi..knor at 2-3-4-5 psi. It kinda does what it use to do "stock"...which is, open loop kicks in at 4.5k rpm. Btw I'm only boosting 7-8psi.
Eveything is hooked up right...checked and reloaded the map 3 times. All settings are good, the only thing I haven't done is reset the ecu each and every time I reloaded the map. I can't see that making any difference.
Any comments or suggestions would be great, thanks!
