Lucky you, cant wait to see some installed pics and impressions
Ask and ye shall receive...
We're all pretty familiar with the first two.
Tubes installed
Finished product
Problem to address with vendor, back tube has a nasty little crumple in it. Might be as easy as trimming the hose some, just not going to do that on $90 tubes without some direction from them. It's sum-b**** to get around the TMIC inlet too.
EDIT Talked to vendor, the crumple is normal for this, they are going to try to redo the pipe in the future.
I've only been about 4 miles since installing the parts, so I don't have any impressions yet. Funny how everything makes a new noise though! CAI = whooosh, PUH. Mounts = vibe's and shifter noise. BPV = banging a tin can sound (kind of a "tink")
I'll take it for a little road trip this weekend and see how it goes. Install was pretty easy, some of the hose clamps are a b**** to get to in the factory location. Other than the tube there are no fitment issues. This sucker is a lot bigger and heavier than the stocker!
** UPDATE 3/4/09 **
The collapsed rear SU boost tube never really set well with me, I tried to modify the SU tube and ended up messing it up.. So, I ordered a set of OBXRacing tubes from Darkstar (see vendor reviews to see how that went) mostly because they are cheaper. I think they are a better set, or at least the rear one is since that's the only one I used. It's longer on both ends and does require some trimming to fit, but it's also a lot thicker than the SU tube and didn't collapse. They also included T-clamps instead of the regular clamps, they do work better too.
On the down side, the front right TMIC mount broke at one of the bends. That really sucks.
