Can peoples post their shift RPMS as well? 26mpg is a lofty goal for my 22 MPG car and I'd like to see whats influencing people's mileage. Shift points and cruise rpms would help shed some light on that. Do you cruise at 30 mph in fourth at ~2200 rpm or fifth at ~1900 rpm?
And in the winter, I'm getting 217 miles per tank - thats 17.36 MPG.....ouch!
It could be fuel differences as well. If you are using fuel with high ethanol content you can expect a drop in MPG.
Additive packages are also different in the winter and summer, which can effect mileage.
Anyway, for me if I want to get 25+ in my mixed city+hills driving I have to really pussy-foot it. If I am on flat land I shift at 2k rpm. If I am in a hilly situation or high load, I'll shift at 2500 or 3k depending on the situation. I do live in a hilly area and I have to accelerate to 65mph up a hill just to get out of my housing area. Depending on traffic I usually have to shift at 3k just to keep from getting run over, with a moderate throttle input.
Also it helps to stay off the throttle when it's not necessary. There is no need to stay in the throttle when you know there is a red light coming up, or a stop sign. I also use hills to my advantage - since I use so much gas going up the hills, I typically coast down the other side. Basically you need to analyze every moment you are on the gas and make adjustments. This is also where it helps to monitor an instant MPG meter, to get a ballpark of how much gas you are using for that moment.
You need to avoid bumps in the road, they eat up forward momentum. Don't slow down as much for turns. If you know there will be nothing to slow you down for a long stretch of road, accelerate briskly up to the speed you want to travel at. This takes less fuel than poking up to speed slowly (unless you will be stopped by a light in a block or so)
I get better gas mileage on my stock wheels/tires than I do my track set. My track set has more sidewall and tread width and of course a fairly soft compound all of which eats up forward energy. The stock wheels/tires have less sidewall therefore less flex, and of course a smaller footprint to cause friction. It is very important to keep your pressures up. I run at about 36psi or so, for the steering response it gives but as a side benefit it is better for mpg.
Even when I'm not a good boy for an entire tank, I can still get 24-ish employing those methods for at least half the tank.
There is a lot to it, if you get crazy about it read up on hypermilers. A lot of hypermilers techniques are dangerous and stupid on public roads with traffic. Like coasting for long distances or up hills can get you killed by a car or shot by an angry driver! But they can get amazing mpg results - especially when they start performing aero mods to their car. They can take a normal 30mpg max car and get 40-50 out of it.
