fastest msp 1/4 mile time
so some of you will be pissed but ill share my good news haha, i got a block,crank, brand new Wiseco pistons 8:5:1, brand new Oliver rods and a fmic for 500 bucks haha im on my way to catch some of you haha
damn.. that's a hell of a good deal you got there...
yeah it is haha saved me what 3k atleast
EDIT god i love your car haha i cant keep my eyes off your sig haha
Thanks once again.. i have updated my cardomain site, added more pictures and did an HDR Effect to all of them....check them out if you haven't already..
I just got my car back breaking in the engine as of now hoping to break 12's. Anyone know if it will be possible with this kind of setup?
Car Specs
Forged 8.5:1 @ 18lbs boost
GT28RS Turbo
Port & Polished Heads
Ported Intake manifold
Steedspeed Exhaust manifold
Hi-Boost FMIC
MPI Tuner
Thermal Exhaust
Weapon-R secret intake
AEM true boost guages
ACT stage 3 clutch
Cryo Gears and LSD on transmission
Custom Down Pipe
Walbro 255 Hi preasure fuel pump
Perrin Fuel rail
440cc Injectors
AWR motor mounts
Can the MPI control timing?
If it cant i dont see you running 20psi without have some problems.
From what i have been reading we are stuck at 15psi without the ability to control timing.
edit: just saw that you changed it to 18, still though you might run into some problems
Well it is still in tuning like I said breaking in the motor still, I also have a split second afc, which someone told me I wouldnt need to do anything with the timing so i was not sure. After saying that is it possible for this setup to run 12's or no?
You should be able to get into the 12s with that setup but traction is going to be the issue to get there.You will have to have a good lsd and run slicks.Running slicks on your car is not good for the stock tranny and axles though.
I think the axles will fine for right now but your tranny might drop 3rd gear cyro treating is nice but its not enough. I would use the MPI not the afc because at that high of boost im sure you will need to pull some timing, but im no expert on tuning by any means.
Ok, so I could get 12's...I do have an LSD. I kinda figured slicks would be hard on my axels when it pulls and that is prob my weakest point. Thanks for the feed back
