First lemme start by saying this gauge is better than the Dashhawk IMO. Go to http://www.aeroforcetech.com/Mazdatech.html Here is what the scan gauge does! Video is at the bottom of the page! This gauge also lets you check engine codes and clear them right from the scan gauge!
IF U WANT TO ORDER EMAIL realtuned@yahoo.com and tell them ERABBIT23 sent you!
RPM
MPH
Knock Retard
Intake Air Temperature
Boost air temperature sensor voltage (post turbo)
Boost air temperature (calculated)
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor (A/F ratio, Lambda) on vehicles with factory wideband O2 sensor
Commanded Lambda and A/F ratio
Fueling status (open/closed)
Wideband sensor output current
Manifold Pressure in PSI (Boost pressure for factory turbo/supercharger applications)
Ignition Advance
Engine Run Time
Battery Voltage
Throttle Position Percentage
Engine Load
Direct Injection Fuel pressure
Calculated Horsepower
Instantaneous and average fuel economy
2 user configurable analog inputs**
Injector Pulse Width
Injector Duty Cycle
Valve Timing
Transmission Temperature (Automatics)
Here is a video installed in my car:
http://www.youtube.com/watch?v=mD6TIBU30TM&feature=channel_page
RPM
MPH
Knock Retard
Long Term Fuel Trim
Ignition Advance
Engine Run Time
Battery Voltage
Engine Load
Injector Duty Cycle
Valve Timing
