I've gotten the RR front and rear mount inserts, and am less pleased with the performance so far.
I installed the front mount inserts with little issue and immediately noticed reduced engine movement. However, only a few weeks afterwards, the vibrations returned, so I installed the rear mount inserts today. What a giant pain in the arse that was!
Now the in-cabin vibrations are unbearable--EVERYTHING rattles now, and the engine vibrations are still a real pain. Clutch engagement is now accompanied by even more chatter and vibration than before I installed either front or rear inserts.
Did I waste 4 hours installing the rear mount inserts when what I really needed was a side mount and/or transmission mount or mount inserts?
And are the RR mount inserts known for adding significant in-cab vibrations? I chose them because I thought they'd be softer and transmit less vibrations into the car than true replacement mounts. If anyone has experience with both inserts and replacement mounts, let me know if this is false logic.
Any help would be GREATLY appreciated. I want to find a solution that will reduce vibrations while keeping the clutch shudder to a minimum.
