fostersafb
- 2009 Mazdaspeed3 GT MGM
So My wife and I took the MS3 from California out to our family in Colorado. One way so far, about 1400 miles. Towards the end of the trip the car started doing some weird things. I first noticed it while using cruise control, which we used for as much of the drive as possible. During normal cruising, 70mph, the car would sort of hiccup and stutter very abruptly then would be fine. It felt like fuel cut or when you start to run out of gas. So I turned off the CC and still did it. Then I thought, maybe the auto climate control could be the culprit since it cycles the A/C off and on constantly and I thought maybe there was a problem with the compressor. Also, the temperature varied from about 9 to 25 degrees while it was happening. In addition the altitude varied between 4k to 7k feet. Turning the A/C off didnt make a difference. Next I tried some different RPMs to find a possible pattern. It only seemed to happen in 4th-6th gears from low rpms. As soon as the I hit the gas it would do the fuel cut stutter then after continuing to accelerate it would just stutter and not really pull at all. To me it felt like it was running extremely rich but I'm no expert.
Is it just the ECU trying to adjust for the varying temps and altitude? If thats the case it would seem that it should be able to compensate a little more smoothly than it is.
I'm out in Colorado untill the weekend, and want to find out if I should take to a dealer out here before driving the 1400 miles back home.
TIA
TIA
