I got my vent pod today... Wow, install is easy and only took 15 mins!!!! Actually, removing the OEM vent and installing this one, only takes 3 mins if that long. Whats awesome is that there is no need for cutting or drilling.
Here are a few pics:
Install is easy, just pull out your OEM vent (it simple slides out with some force, but not brute force), the turn the inner ring clockwise and slide out...
You have to remove the panel that runs underneath and around the steering wheel.
Unhook the hood release cable, slide out the handle (you need to use a flat head screwdriver and wedge it between the dash and handle to depress the locking mechanism), and remove the screw behind it, then the panel just pulls out; its held be clips.
Route your wires.
And install your gauge into the vent pod.
Here are some final pics.
Definitely better than having the gauge on the steering column.
