True performance drivers want to know exactly what is going on with their vehicle at all times, but much of this detailed information is typically only available through supplemental gauges. But at a minimum, adding an accessory gauge increases clutter and decreases visibility around the dashboard, and typically requires some form of cutting or drilling into your valuable vehicle.
The new VentPod Single Gauge Pod is cleverly designed to integrate in the Heating, Ventilation and Air Conditioning (HVAC) vent of any Mazda 3 / Mazdaspeed 3. Installation is simple – just remove the HVAC air louvers by gently pulling outwards to remove. The VentPod then replaces these louvers with no cutting, drilling, or trimming required. Installation takes only a few minutes.
Those concerned that the VentPod will obstruct the air through the system can rest assured that there is no significant loss of air flow for the cooling and heating functions.
The VentPod will fit any standard 2-1/16 inch (52mm) gauge. The unit is low profile and designed to match the interior of the vehicle.
