Anyone Have Pics Of How They Wired Up Their Gauges
NYSP33D3
07' Cosmic BLue Mazdaspeed 3
Im in the process of installing my Prosport gauges.. I have Boost/ A/F , and Oil Pressure.. I ran my wires and got all the mounting done.. now im just wiring it up, Anyone have any pics or instructions for how they are supposed to be wired up?(huh)
The gauges should have come with instructions on what wire goes to which color.
You have all your sensors installed? Did you mark which wire went to which sensor?
Everything is in place it all just needs to be wired up.. I dont know what they mean when they label the green and white wires as (NOTE).. I have no idea what that means... I know the basic power and ground(braindead
Q: I lost my instructions how do I wire the performance Series gauge?
A: Black –Ground
Red - 12v ign. power-meaning power when the ignition is on.
White- 12v ign. power
Orange-Headlight switch.
Green - Sender
The above wiring will result in white during the day and color (amber or Green) at night.
Q: How Do I wire my Premium Series Gauges?
A: Red -Constant 12v power
Black-Ground
White-12v ignition power
Orange-headlight switch
Green –Sender at night.
A: Black Ground
Green - Sender
Black-Ground
Green Sender at night.
THANKS(usa)
Install wasnt as easy as I thought it would be... It seems like Mazda makes EVERYTHING harder for people who like to mod their cars.
No prob!
And Tell me about it. lol. I wired up Prosport Oil temp, oil pressure, and coolant temp gauges. Hardest part was getting all the wires through the firewall
No prob!
Truth Be told.. Im about to do i now.. Just eating my breakfast (Smokin a blunt).. lmao.. Then im gonna get started.. SO you hooked up your "night" time the orange wire to your headlight switch?
I wired my "headlight" switch to a seperate manual switch. At the time, i had my foglights wired up so they came on with just the parking lights, so, i wanted to still see the gauges in teh day time with lights turned on.
If you don't have yours wired up that way, you can wire straight to your headlight wire, so as soon as you click your headlights on, they'll dim
Alright.. and as far as the Air Fuel ratio gauge.. I tap into the 5 wire harness to the 02 sensor right by the battery cover right?
I'll leave that to another speed3 guy. I didn't do A/F gauge, plus, i wired up a Protege. lol
What kind of A/F gauge do you have. There are two O2 sensors in the MS2, a wide band and a narrow. You can tap into the narrow band one (it's the one between the two cats) but don't expect the gauge to tell you anything useful. The wide band cannot be tapped; if you have a wide band gauge you have to drill the down pipe and weld in a bung for the sensor.
SO What your saying is i cannot wire it up unless I get drill into the downpipe? What about splicing into that first sensor?
Why cant I use this wire for the air fuel? Isn't it the same connection that runs through the downpipe?
