Need help! Not boosting past 11psi
ComeBack
Mazda MazdaSpeed3
Hey i just installed a halman mbc, and atp bck. Im doing my pulls in 4th gear and no matter how much i turn it up the max psi i got was 11.02 with a/f's at about a 14. Does anyone know whats going on? I just unplugged the battery and was about to go try again.
Thanks
It sounds like the ECU boost solenoid is out of the picture for some reason. Maybe the wire to the solenoid fell off or was damaged? Or maybe you installed the MBC in such a way that the solenoid can't bleed off the pressure to the waste gate.
my friend was boosting the same as you no matter how many turns it still only boosted 11.5 so we just hooked up mine and it was fine so it ended up being a bad boost controller!!!
well now there is a new problem, my boost gauge is reading about 20psi now, and my dashhawk is only reading like 6.7
