hahah I can shift gears without even using the clutch...
havent tried it in the Speed 3 yet beccause of the sometimes vagueness of the cable tranny. But on the Speed Protege...alll the time...
Oh and in a Formula Mazda...one of these...
Which I have driven a few times...you dont use the clutch at all once in motion as its just a little lift off the throttle to upshift and heel and toe without clutch on the downshift. Its not a sequential box either its H-pattern. The gearbox is actually from an old VW BUS hahahah.
Car weighs 1300lbs had a 13B engine in the back rated to about 180hp...slicks and wings obviously...my kart accelerates quicker and corners harder, but this has higher top speeds...135-140 flat out..can be geared for 150+ though but most tracks dont require it...
Just saying if your REALLY REALLY good you dont need to use the clutch at all...upshifting OR downshifting..
