Warped rotors at 16k miles???
Elite130
The rotors on my M6 are warped already. When I put the brakes on, I can feel the car pulsing a little. I have only 16k miles on the odo and bought the car 6 months ago. Do you think the dealership would cover this under warranty?
My recommendations......
Easy on the flooring to high speeds then braking.
Every case of "warped brake disc" that I have investigated, whether on a racing car or a street car, has turned out to be brake pad material transferred unevenly to the surface of the disc. This uneveness results in thickness variation due to hot spotting that occurred at elevated temperatures.
The obvious question now is "is there a "cure" for discs with uneven friction material deposits?" The answer is a conditional yes. If the vibration has just started, the chances are that the temperature has never reached the point where cementite begins to form. In this case, simply fitting a set of good "semi-metallic" pads and using them hard (after bedding) may well remove the deposits and restore the system to normal operation but with upgraded pads. If only a small amount of material has been transferred i.e. if the vibration is just starting, vigorous scrubbing with garnet paper may remove the deposit. As many deposits are not visible, scrub the entire friction surfaces thoroughly. Do not use regular sand paper or emery cloth as the aluminum oxide abrasive material will permeate the cast iron surface and make the condition worse. Do not bead blast or sand blast the discs for the same reason.
